alastroct Thought I'd check here before buying one.
I have a couple of EDIMAX USB WiFi adapters that work with Raspbian (and thus, with ASIAIR).
However, they are based on the ancient 802.11b/g/n standards. The 802.11ac ones don't work on ASIAIR. The EDIMAX ones that work on ASIAIR are only capable of 150 Mbps.
ASIAIR is nothing but programs that run on Rasbian. If something works with Raspberry Pi, it will work on ASIAIR unless ZWO has removed that function to save memory.
Email Ms. Fried (Ms. Adafruit :-) to see if she knows the speed of the unit that she rebrands. Check too if they work at subzero temperatures outdoors in winter. Most of the very low power consumer devices will flake out unless you heat them.
Amazon still sells the EDIMAX EW-7811Un, if 150 Mbps speed is good enough for you. And that one works on ASIAIR for sure. ASIAIR (Rasbian) switches to using it instead of the internal WiFi radio when you plug them in and reboot.
