Hello,
I took down my mini PC and now just use the ASIAIR Pro exclusively on my two refractors and my 9.25 EdgeHD with ZWO gear 294MM Pro main, 290MM guide, EFW, OAG, and EAF. The auto focus routine works great on both refractors but on my SCT 90% of the time it just makes it much much worse. This is due to the mirror shift that happens when the focus is adjusted which makes the stars wobble for a second or two and makes them appear many times larger. If only you guys could add an option to the AF routine to 'wait' X seconds after a focus adjustment step is made before taking the next measurement it would make this problem go away. Other people with SCTs and the AAP have this issue too so please consider my request.
Thank You,
Walter
