Hi Is it possible to get a higher capacity SD card such as a 64GB - 256GB or a higher USB flash stick
No matter what is your SD Card(64GB, 128GB,……), there always be only 32GB available space after mirror the OS. So we recommend to use U disk.
Add a USB3 stick, there are of 256GB or more
@tech@zwo#46456 So i can use a higher usb stick ?
brandmandsam Of course you can. You can even use SSD.
Oh wow that idea for SSD drive is a good one!
Check usb stick as well
