Instruction
Some ASIAIR Pro user could not Sucessfully connect their ASIAIR Pro to the EQ6-R Pro. After communication with Skywatcher engineers, we build an new OS that could compatible with EQ6-R. Here is the download link of the special OS:
https://drive.google.com/file/d/1fvWM1lenwQP29G9_Q_XCMKhm0_IB2ULH/view
NOTE:The only important thing is to restore the ASIAIR with an OS that is modified to adapt to the new batch of Sky-Watcher EQ6-R Pro mounts. There is a USB port on the body of the new EQ6-R Pro and its production date is later than 2021.01.01.
1 Preparation
- A new MicroSD card and a Card Reader.
- Download the ASIAIR system zipped image file from the Google Driver, for ASIAIR PRO, and unzip it to an image file. Here is the download link of the special OS:
- Software recommended:
2 Restore the ASIAIR OS
Windows
- Insert the new MicroSD card into the card reader, then plug the card reader into the computer USB interface.
- Run the Win32 Disk lmager, click on its interface to select the image file that just unzipped.
- Under the Device label of the Win32 Disk lmager software interface, select the MicroSD card drive latter.
- Click Write to start. It would take 30 to 40 minutes.
- After restoring, plug back the MircoSD card in ASIAIR device and power up, connect to its WiFi on the app.
Mac
It is recommended to use Apple Pi-Baker for ASIAIR system backup and restore. The operating guide is included on this download page and is easy to complete.
Linux
Backup and restore under Linux system, you can use the "dd" command. You can also use the GUI tool Etcher when restoring.
3 Authorization
Authorize Online (Recommended, Internet access is required)
- Click Authorize Online and AISIAIR will automatically complete the authorization. This method requires that the App has Internet access.
- After authorized, the License QR Code will be automatically saved in album for standby use.
Find more techniques in ZWO PKB on how to use your ZWO ASIAIR.
https://www.yuque.com/zwopkb/asiair/
