Hi there
after the update from 8.11 to 8.24 everything worked fine for me! Thank you ZWO for the support.
(EQ6-R Pro new manufactured batch from Jun/Jul 2021)
Right now, I've got just a little "problem"
One first startup with 8.24 on Win10; Bluestacks 5 I got the message that the App version is out of date. I wasn't able to update it and so I choose "not now" and went through the setup.
Any suggestion to fix that on Bluestacks 5?
PS.: If you are not comfortable with Win32 Disk Imager, try the Raspberry Pi Imager
(https://www.raspberrypi.org/software/) and:
- Start Raspberry Pi Imager
- Scroll down to "Own Image"
- Select the ASIair Pro Image
- Select the MicroSD
- Write & Verificate
Worked perfectly for me and was pretty easy to use.
Looking forward to take some great pictures! 😃
