I bought an EQ6R Pro mount in May 2024 to use with my ASIAIR Pro. Today was the first time i tried to connect it and am having the exact same issue. That link above in this thread no longer links to anything.
Doesnt ZWO support this issue anymore? Meaning the only way to get an ASIAIR Pro to talk to an EQ6R Pro is to now buy the EQMod/EqDir cable?
In addition, my other EQ6R Pro mount has a Hand Controller port that no longer works (thanks to this very issue - long story), which would render an EQMod cable useless as it uses that port, and so USB 'needs' to be supported.. this beggars belief!
ZWO support, please help.
EDIT: Emailed Support and I was kindly sent an email with the link to the new ASIAir Pro OS file & instructions. Suggest doing the same if youre in the same boat. Thanks Simon @ ZWO Support.
