So, I finally got the ASIAir Pro to recognize my Motherboards USB port with the Sticky here, however, after the update to the newer version, the device no longer saves any devices attached after a manual, turn off the switch shutdown. A Software restart or shutdown no longer works either, the device turns off all the attached devices, e.g. camera, guide camera etc... but the wifi is still running and the ASIAIR Pro does not shut off, nor reboots. The only indication beep is during start up.
If I restore from version 1.4 as per the restore link (google drive) then the ASIAIR remembers all the devices attached after reboot, shuts down and restarts correctly, however, it does not recognize the usb connected EQ-Mod Mount.
Is there a updated version to support the USB connection for the Skywatcher EQ-6 Pro anywhere?
Is there a config file or something I can copy over to the SD Card to make it work as designed?
Anything???
