tomred Is it possible to re-install the previous version?
You should be able to find previous APK files on the Android device (do a search for files with .APK extensions).
You will also need to boot the ASIAIR hardware with a microSD card that has a firmware version that is no newer than the one that matches the older application. The original backup image that you made when you unboxed the ASIAIR should work fine; just burn a new microSD card from that first backup.
