Just purchased the ZWO EAF auto focuser. Installed the software(s) etc.
First night out, I opened up the appropriate windows and dialog boxes, etc. Hit run to do 12 of 12 image averages and I thought after this step that it would be focused. This thing just kept going, ended up doing 25 of 12 before I finally closed all the windows. Checked my star and it was blurry pretty bad. I also set the preview for (1:1) as required before starting.
Tried this three of four times with the same result. Never did focus, nor complete the imaging process. Forgot to mention that I'm using Astro Photography Tool to operate the focuser.
Any suggestions as to what I can check to wake this thing up?
Thanks,
Rodney
What were the auto focus triggers, what scope, what were your auto focus settings?
Have you done a manual auto focus or even sent a move command to the focuser to make sure APT is communicating with it ok?
Let me get back to you. I'm on the road...Yes, it works great when I type in the numbers manually. I can focus it like that, using the APT Focus Tool...It's on my Meade Series 6000 70mm APO Quad, 350mm FL at f/5.0, scope is almost new. Not sure about what the focus triggers are, or the auto focus settings.
I did find out one thing. After the first night, I double-checked my ASCOM software. Found out it did not update before the first time out with it...I made sure I have the latest version now...Maybe that's part of it...I'm not sure about default settings on a new EAF out of the box...I didn't change anything. I just connected it, and tried it out..
Rodney
  • w7ay replied to this.
    Is there anyone working this Forum? Sure could use some help here...Thank you...
      beachbum it works great when I type in the numbers manually.
      The first thing to check is the EAF scale when attached to your particular focuser.
      Your Auto-Focus Aid box shows a focuser Move Step of 20 and this may be too small to achieve a V curve (the "Hyperbola Fit" in your interface). If you have the EAF connected to an SCT focuser, or to a belt driven lens focus ring, the 20 may well be way too small to establish a curve fit.
      If you have the time, try sweeping the focuser manually and note down the HFD or FWHM of the stars. With enough steps, the star sizes would start from an HFD of 7 or more, down past the minimum (1 to 3 is normal) and then back up to 6 or more again. Note down the EAF step for HFD at about 6 or 7 and then the EAF step when it rises back to 6 or 7 again. Divide the difference in steps by about 5 to 8 and use that as your "Focuser Move Step." This should give the auto focus routine enough data points. You can refine the numbers later.
      Also, start with the telescope already in moderately good focus. These "auto-focuser" are really auto-micro focusers. They don't do a full sweep for you, like the auto focus lenses do. You need to be close to start with, and it will try to make it pin-point focus.
      By the way, don't expect ZWO to answer on this forum on weekends, or during non-office hours in China (and even then, rather sporadically). You will only find kind souls like Walter, above, trying to help out a fellow hobbyist.
        beachbum Hey sorry, this forum doesn’t send notifications unless to log into it to see if there new posts. But basically Chen nailed it, and I would defer to his answer as he is the resident expert volunteer here. Any replies you get from ZWO will be canned responses.
        For what it’s worth I have a small refractor, a 72mm. The whole focuser has a travel of 9cm (aka 900mm) which take 21,000 EAF steps to rack from one end to the other, so basically 23steps/mm. I set my AF step size to 50 steps and exposure to 3 seconds. So at the start of the AF routine my confuser moves out about 1cm out and starts moving back taking exposures building the focus curve up to 1cm past the starting point. This amount of movement, in my case, ensures that fine focus will be found somewhere within the range covered by the EAF.
        i suggest you change the step to something ridiculous like 200 and then run the AF routine manually and watch your focuser just to verify that it runs. Once you verify it does run, run a sequence during the day just to verify APT actually triggers the AF when it’s supposed to. Once you have verified both of these are happening it’s only a matter of finding the right step size and expose time (don’t leave it at 200). But as Chen mentioned none of it will work if your scope wasn’t pretty close to fine focus to begin with.
        Last night I connected it and ran it all the way in, then Zero'd it. My Meade refractor is 70mm, and has a 32mm total focal travel. I ran it all the way out and I had 8,500 steps. 200 would barely move it.
        if I can ever get some clear skies again I'll test it. I'm on the Florida Gulf Coast and we're dealing with all this gulf moisture now...
        If you noticed in my previous post I mentioned that I was using the older version of ASCOM after thinking I had upgraded to the newer version. Which I did not, so maybe that could be the issue.
        Thanks for the comeback,
        Rodney
        w7ay
        Yeah, now that you mention it Chen, I saw a you tube video where one guy said 20 did not work for his focuser. He changed it to 40 and it worked. I was going to do that next go to a 40...
        Not real sure what all those numbers mean your referring to. I'll have to figure it out with some study and research. I'm using the ZWO PDF instructions and going page by page reading it.
        Roger that on the time difference...I lived in the Philippines from 2011-2017, same time pretty much, back here in the US now so I have to deal with the time diff...
        Appreciate the help! I'll figure it out...
        Rodney
          beachbum one guy said 20 did not work for his focuser. He changed it to 40 and it worked. I was going to do that next go to a 40...
          Mabuhay Rodney,
          On my two Takahashi scopes' rack and pinion focusers, the EAF moved the drawtubes by about 4 µm per EAF step (so, about 250 steps per mm of drawtube movement).
          On a belt driven Askar ACL200 lens with the same EAF motor, the lens only moves by 0.44 µm per EAF step. So over 2000 steps just to move the lens just by 1 mm.
          If you'd attached the EAF to the slow motion shaft of the focuser, you are likely to see something closer to the Askar lens than to the R&P focuser on the Takahashi.
          The number of steps wil also depend on your focal length. In general, the depth of focus is shorter with shorter focal lengths. So there is really no one-size-fits-all solution. You just have to figure it out for your own case.
          The HFD I mentioned is the "Half Flux Diameter" of a star; a measurement of how large the star is in pixel units. There should be something that your program should be able to measure for you. It pretty much corresponds to the vertical axis of that hyperbola curve in the screen capture that you posted.
          When you focus on a star, geometric optics predicts that the star size will change linearly with focuser travel. So, HFD will change linearly with EAF steps. However, as you approach focus, the star size becomes diffraction limited and focus no longer improves as you get to perfect focus. The diffraction limited region is the Critical Focus Zone of the optics. A good match to the HFD data points is a hyperbola; so that is what is used to estimate the actual focus without having to land on the exact focus while you are building that v-curve.
          The one thing that you need to watch out for is the backlash from these stepper motors if you manually focus.
          Because of backlash, most of the autofocus programs I know first moves the drawtube in one direction away from the focus point and then step the focuser only in one direction as it measures the star sizes.
          Once it is done, and it can now fit a hyperbola curve on the star sizes to determine the EAF position needed for perfect focus, it then again moves the drawtube to that same initial point that it had started before sweeping for the EAF steps. From there, it moves to the final focus setting using the same direction that it makes for the star size measurements. This way, the backlash is cancelled out, and you don't have to worry even about measuring the backlash when using these autofocus routines.
          You do need to measure the backlash if you are manually controlling the electronic focuser and rocking it back and forth to achieve focus, otherwise it is an exercise in frustration when looking for focus.
          As you said, you will figure it out after you are familiar with how these gizmos work.
            w7ay
            I'll keep all this info and look at it Chen...
            Salamat Dong!
              beachbum
              I had never been to the Philippines, but had lived for some years in Thailand and Malaya/Malaysia. There are many common words in Malay and Tagalog. Certainly, Selamat is one of them :-). (Useless trivia department: "soap" is "Sabun" in both Malay and Tagalog, and "Sabu" in Thai.)
              Clear skies,
                w7ay
                I was stationed at Udon Thani, Northern Thailand with the USAF during the Vietnam Days early 70's...Love the people there! so friendly...
                Rodney
                Write a Reply...
