Has anyone tried this combo? I would like to try it for EAA. I currently use the AZMP for EAA using a laptop but I understand the mount can be controlled with the ASI Air Pro. Can anyone confirm that?
Also, if using them together, would I be able to use the GPS based alignment process with the AZMP since obviously polar alignment with the Air will not be an option for aligning the goto functionality.
