jayair I connected to my computer and I can see the mount connection.
OK, it is a matter of making the ASIAIR see the mount.
In my case, when I restart the ASIAIR app with nothing connected to the ASIAIR USB ports, and selecting RainbowAstro mount in the Telescope Setup window, it shows Serial port as "Not found."  As expected.
If I restart (quit app on iPad and relaunch ASIAIR) the ASIAIR app with even an empty USB hub connected to one of ASIAIR's USB ports, Telescope Setup will already show Serial: No Connected once I select the RainbowAstro mount in the Telescope Setup window, without trying to connect yet.  I.e., ASIAIR sees some USB port connected to it; it does not know yet that it is not a mount.
ASIAIR will fail to connect to a "RainbowAstro mount" of course, when my mount is not plugged into the hub.
So, the next thing for you to try is to find an unused unpowered USB Hub around the house, and plug that into the ASIAIR.
Not all powered hubs are compatible with the Raspberry Pi (most cheap hubs will back-power the USB port in the Raspberry Pi), so it is best to try an unpowered hub first.
The short experiment that I did above was done with an unpowered hub (a powered hub with no power conected to it).
Does ASIAIR now report Serial:Not Connected instead of Serial:Not Found?
Remember that each time you connect or disconnect a hub or device, to at least relaunch the ASIAIR app, before checking the Telescope Setup to see if any state has changed.
If ASIAIR now says Serial: Not Connected (instead of Not Found), plug your mount into the hub, and restart the ASIAIR app.
See if it continues to say Not Connected with the mount connected to the hub.  If it does, try to connect to the mount (that slide switch in Telescope Setup at the far right of the mount drop-down menu).
If it now connects to the mount, the Raspberry Pi probably has a problem with the USB hardware on the mount (I have seen incompatibility with the SiliconLabs chipset), and you may have to keep using a USB hub between the ASIAIR and the mount (host port of the hub is the ASIAIR :-).
Now, if ASAIR does not even say "Serial: Not connected" after you connect a USB Hub to the ASIAIR (with no other USB devices connected to the ASIAIR), there is something really wrong with the Raspberry Pi port if it fails with a couple of USB hubs.
