Is there any guidance on the rate that the 2600mm/mc should be cooled or warmed to avoid sensor damage?
See this thread:
https://bbs.astronomy-imaging-camera.com/d/12792-how-quickly-should-i-cool-my-asi-camera/7
That doesn’t really help much. Hopefully, ZWO will address more specifically.
umasscrew39 Is it because you use APT and there is this statement about the sensor damage? Then you don't need to worry about this, we did not announce anything related officially.
ok- thank you. No- I do not use APT. I use SharpCap but was just curious if this could be a problem as others have mentioned it could be a problem.
Thanks. I was alerted to this potential shock damage by APT, but it seems it's not a concern.
