HI. I would like to know if ASI studio can do any of the following things: 1) Give a fine focus HFR score 2) give pixel stats so i can callibaret my flat frames 3) allow control over again to a specific number ( i just saw two options high and low). Any help much appreciated.
If you want these things just like the Nebulosity, at least attach some screenshot of Nebulosity about what it looks like then I can convey to our devs if they will be implemented. Thanks!
I did not know whether not ASIstudio has these or not. But give your reply Im going to guess the answer is no. Given that here is an article with screen shots on the fine focus functionin Nebulosity http://www.stark-labs.com/help/blog/files/category-ask-craig.php An article about Gain here: http://www.stark-labs.com/help/blog/files/GainAndOffset.php I have also attached an image showing the gain control, notice it has a numeric value not just high or low. . I have also attached an image showing the pixel stats , again this is needed to take correctly illuminated flat frames.
skydveiphil Yes, the answer is no. You can take ASIStudio as elementary while Nebulosity as advanced.
