Basstro65 Anyone now how I can get round this screen SCP issue.
I am curious, is the picture that you have posted that of an iPhone screen?
There are two things that come to mind.
One is the red exclamation mark on top of the WiFi Menu of the top left of the screen shot. See if you can make it go away by being no more than a meter from the ASIIR. (Yes, ASIAIR's WiFi range is that bad, especially in a WiFI congested suburb.)
Next, you might not have given sufficient permissions to the app (if this is indeed an iOS screenshot), and ASIAIR is pushing the wrong Latitude to your mount.
If the ASIAIR app's Telescope Settings window show the correct Latitude, the following is not needed, but in case it does not, give it a shot.
Check for the ASIAIR app settings in the iOS Settings window (scroll the left panel of Settings all the way down to the third party apps, and pick ASIAIR from that alphabetically sorted list). Location services should be set to "While Using the App" or to "Always." Also turn on Precise Location to get Assisted GPS (your device's GPS is augmented by cell towers' locations); that will make your Meridian Flip time more accurate (ASIAIR depends on precise Longitude to determine when to choreograph the auto Meridian Flip).
You will also need to allow Photos access in that same Settings window if you need to save images and movies from ASIAIR.
