Carlos,
I did a google search and a number of threads on the subject says the optimal backfocus of your coma corrector depends on the focal length (just as I mentioned earlier).
With a 600mm focal length, the backfocus is 51.66mm, with 800mm focal length, the backfocus is 53.66mm, and it is only the 55mm value for 1000mm focal length. For focal lengths that are longer than 1000mm, you again need a backfocus of less than 55mm (54.66mm for focal length of 1200mm). 55mm is the longest and only works at 1000mm focal length.
Here is one of the threads:
https://stargazerslounge.com/topic/352068-f4-800mm-with-skywatcher-aplanatic-spacingback-focus/
and it references a YouTube video that gives the backfocus (the numbers that I just mentioned) for a couple of different focal lengths
https://youtu.be/6YLcXEUgjbM?t=1033
So, mystery solved. But it means that if you have a focal length that is different from 1000mm, then drilling those 4 holes might be your only option. Even using a new ZWO filter wheel won't help.
Or, use a guide scope instead of an OAG. If your focal length is not too much longer than 1000mm, a guide scope should work just fine as long as there is no differential flexure.
