iceking Can I use Baader UV-IR-CUT Filter - 2" on ZWO M42 Filter Drawer? Thanks!
Baader 2" mounted filters don't always thread nicely into the ZWO filter holders. Not a height problem but a thread problem.
If you try it and it does not seat in completely, just find a cheap 2" filter (something like a SVBONY filter) that works with the ZWO drawers, and swap in the Baader glass into the cheap filter 2" mount (just toss the SVBONY glass away). You probably already have a "lens spanner" that is used by photographers; but if you don't, you will need that tool to swap the glass.
