Hi Denali and @tech@zwo#49163 , unfortunatelly I've the same problem with both new ASI294MC PRO and the ASI 120 mm Mini. If I connect the 120 mm Mini only all works fine. If I connect the 294MC Pro only all works fine, but, as soon as I connect both cameras de 120 mm Mini is fired and doesn't works. I found that the only way to get estable the system is connecting each camera to a different USB port to the laptop instead to use the HUB where I've connected the mount and both cameras. I would like to mention that my USB HUB has is own power supply. Something is happening with PHD2 or ASCOM or Native Driver. I don't know. I remember that @jays_ct and @mcerono got the same problem with their 2600 and 1200 mm Mini. Apparently ASCOM and Native driver are not talking between them and I think that both try to use same Port Comm???? Colud be an idea. When My 120 mm Mini is fired, ASI Studo takes images from 294MC Pro and I get the same image from PHD2 so both Software, despite are connected to "differnet cameras", 120 mm Mini to ASCOM and 294 to Native Driver.
As PHD2 offers 2 ASI Cameras (ASCOM) to connect, I've tried both while the 293MC Pro is connected with Native driver with ASI Studio, but allways with the same succes, the 120mm Mini is fired.
Quick Help would be appreciated!!!
Best Regards,
Frank!
