is there possible to command servocat alt-az mount with asiair pro ? and use skysafari to move telescope ? I use actually a Nexus dsc for that but use asiair for cam : need 2 tablet for control... best...
Does Indi library mention this support?
i was wondering if there is no way to make common network with the nexus? The nexus has an indi driver like the Lx200.
j65 Do you mean Meade Lx200(supported)?
The protocol use for Sky Safari to communicate with Nexus DSC is LX200. I look to connect asiair in wifi station mode 2.4ghz to have a single network communicating between the tablet, the asiair and the nexus-servocat couple. Is it a good idea ?
j65 What you are asking is for SkyWatcher AZ-GTi: https://astronomy-imaging-camera.com/manuals/ASIAIR_Sky-Watcher_AZ-GTI.pdf Not sure if it is going to work with your current setup.
I would test that next week on my return from vacation ... if by then someone has an idea, I'm a taker .... thank you
