pemongillo The ST4 cable only allows for sending guide pulses via the guide camera to the mount. For more control of the mount, including a meridian flip, indeed a USB cable from the mount to the ASIAir is needed. And then the ST4 cable can be omitted.
The hand controller of the CEM26 needs to be connected to the mount in the normal way. Then the other USB cable needs to be connected from the hand controller to the ASIAir. When the ASIAir app on your mobile device is started, you need to select the CEM26 as mount. Also make sure that guiding is done via the mount and not via the guide camera. That’s all.
