Hi All How do I stop the included thread adapter from continuing of the threads when using an extension tube. There is no thread stop inside the filter holder so the thread adapter just continues to screw into the holder until it comes off the threads. Am I missing something here?
Thanks
mpucci kenhaw I solved this by adding a very large, thin washer between the two components. It has to be thin since the m48/m42 adapter isn't very thick and large enough to provide support for both components.
Hello, What is your camera? Can you provide some photos about this?
Hi, i continue the thread because have the same problem. The issue is not on camera side, but on extension tube side. If you screw the m48/m42 adapter, this doesn't stop and is impossible to fix firmly the camera to the scope. Thanks
