Jarno,  are you using the StarGO in conjunction with the Linear?
This is what the StarGO manual says:
In the case the object to mount is located in the other side of the Meridian the GOTO will cause a Meridian Flip to avoid mechanical interferences between the telescope and the tripod or the column.
https://www.swagastro.com/uploads/2/3/3/7/23377322/stargo_user_manual_rev1.7.2.pdf
So, indeed, it should have Meridian Flip built in.
Most mounts (in fact, almost all of them) do not even have a "perform Meridian Flip" function.  The Meridian flip for all the German mounts are implicit -- when you command a GOTO after the hour angle of the mount has gone past zero (i.e., past what the mount considers to be the Meridian).  Do the experiment that I suggested in my prior reply and you should see it do a Meridian flip.
Once it is determined that the Linear can Meridian Flip, all you need to do is to set the two times in the auto meridian flip setup in ASIAIR to choreograph the whole thing (i.e., first turn off autoguiding and tracking, then wait for the second time parameter to arrive before sending a GOTO -- that then should make the Linear go through a Meridian flip).
(That said, I rarely use the ASIAIR auto meridian flip function -- for me astronomy is a technical hobby, not a selfie taking machine, and I enjoy controlling the telescope myself.  Same thing with the ASIAIR auto focus; I compute my own V curve, and when it is not cold outside, use a Bahtinov mask for the fastest focusing and most precise process there is; even under poor "seeing" conditions.)
By the way, this article describes the Frauhofer mount (which is unfortunately called just "German" mount today, instead of after its inventor -- many other contributions including spectral lines, lenses, etc), and it mentions Meridian Flip :-)
http://www.astrosurf.com/re/fraunhofer_great_dorpat_refractor.pdf
As noted in the article:
Some regions of the sky are only accessible after performing a meridian flip of the mount (by reversing the telescope about its polar axis).
