J_Edit61 Where do you change the exposure time for the PS process? Is there even an option?
Jim,
Plate Solving from the Preview window just uses the exposure time that you have chosen in Preview.  Ditto Polar Alignment window, which has its own (plate solving) exposure time.
Plate Solving exposure time during an Auto-Center after a GOTO is set in the Telescope Settings window.  If you had turned on "GoTo Auto-Center", Telecope Settings will let you set the exposure time there.
Yep.  Poor UI design.  It should all be in one place so you need only edit it there.
