I just bought a 6200 ... I have to say it's a HUGE disappointment.
This camera displays HUGE vignetting - it is in the CAMERA - not the optical train.
I set the camera up on an Askar 130 which has an image circle of 60mm. All the intermediate elements are M54 - so I wasn't expecting any vignetting at all. After a few exposures, I was perplexed by the significant vignetting, so dismantled the optical train piece by piece to try to identify the culprit. I eventually got down to just the camera - no filter wheels, no OAG, no tilt plates - just the camera - and the vignetting was still there.
Then I set the camera (with no attachments) up on a flat panel and took a number of exposures at various settings.
THE VIGNETTING IS IN THE CAMERA.
The difference in brightness from the centre of the sensor to the corners is 30%.
THIRTY PERCENT !!
That is rubbish performance.
If course I know vignetting can be managed using Flats - and that is fine for vignetting introduced by elements in the optical train.
But I DO NOT expect vignetting in the camera.
Vignetting in a camera is NOT normal - that is rubbish.
Not for a camera that cost me USD 4,700.
I would NEVER accept this terrible performance in a Nikon camera - or even in a consumer camera that cost fifty bucks. Why should I accept it in a specialist 'Pro' camera that cost a hundred times a much ???
It is going straight back to the shop for a refund.
