Lain402 I am a big fan of sarcasm but maybe it should be avoided in this case.
Canarisky No this certainly is not enough for all your equipment. Your camera alone can run about 3 to 5 hours on such a power tank, depending on the amount of cooling needed. For the ASIAir Pro, mount and EAF you will also need more power. The EFW usually gets powered via its USB cable connected to the camera.
