pemongillo what you describe is exactly what is described in several other post and what wvreeven and myself happened. You write „usually“ which is not „no“. The issue you describe happens with some mounts (iOptron, sometimes AVX), when you connect SkySafari (and probably other third party software) to the mount via AAP. For iOptron one connect and positioning with SkaySafari is enough to get AAP struggle with any following calibration, a disconnect before will have no effect. The communication is in dissorder and you will see the backlash error. As said, probably you will see the effect also with other software you work with in parallel, sending commands to mount via AAP. I don’t see the error any more since using only (completely) AAP.
If the problem for you will not be solved this way, try the following workaround:
- when error occurs, stop calibration
- disconnect mount in the mount menue
- wait a few seconds, connect again
- sync to mount in mount menue
- back to guiding and start calibration again
this worked for myself and several others.
Markus
