Go to the hand controller of your mount.
Change all the slew speeds back to the factory default values that came with the telescope mount. Ask the manufacturer, or a friend with the same mount, what the default values are, if it is not in the mount's manual.
ASIAIR assumes that the slew speeds are of a certain ratio when it attempts the 60 degree move. Yes, ZWO's algorithm is brain damaged, but that is what you get. A real "simple as 1,2,3" device would have discovered the speed ratios by itself before attempting the 60 degree slew. Instead, it depends on fixed ratios from the factory defaults.
