I have the same issue! I cannot connect to the ASIAIR+ unless I turn off “Cellular Data” on my iPhone. It will not connect even by IP address, in spite of the ASIAIR SSID being visible in the top left. Once connected, I can turn cellular data back on and it does not disconnect, however. This is an annoying bug which should be fixed! This is not necessary on my iPad, which has no cellular.
