I selected and have been trying to use an ASI183MM (non-cooled) as a guide camera for a while now. It makes a fantastic guide camera - when it works... It has low noise, it reads out fast enough with ASCOM, and it has a large FOV. The problem is it "fails" or has some kind of error nearly every night. I'm "old school" and use MAXIM DL (MDL) to guide via the ASCOM driver.
Example: Last night the MDL/183 combo got stuck on "reading ccd", however other nights the 183 seems to lock up and the driver just sends the the exact same image buffer over and over. Because the image does not change, MDL thinks that the guiding is "perfect". Some nights the system just reports a "guider error". I have jury rigged my automation software (CCDC) to restart the guider after each filter change which can often save a night's imaging depending on the failure.
I have replaced and tried different (all high quality) USB cables, Hubs, and USB controller cards. Due to how my system is configured I must use an "on OTA" USB Hub (now a Pegasus Astro). One important note is my observatory is (over 2700km (1700mi) away - so lots of hardware swaps are a pain.
I found USB 2.0 to be much more reliable than USB 3.0 and I do not require the 3.0 speeds. USB 3.0 seems to only work for a few minutes before failure. The most reliable thing for me is everything is USB 3.0 but is plugged into a USB 2.0 port on the computer. All of the USB connections are "strapped down" to reduce/eliminate connection issues from cable movement. I feel I have done all I can with hardware and connections. The other cameras on my rig do not have these issues.
I know it is a long-shot to ask, but any suggestions?
