UV IR-CUT D60 window AR D60 window
What does it have originally? Which one should I buy to use for 2600mm with refractor?
Hello, AR window for 2600MM, IR-CUT for 2600MC, you don't need to buy another one to replace.
@tech@zwo#50977 scratch on window. need to replace. right item? https://astronomy-imaging-camera.com/product/zwo-protective-window-asi-cameras?attribute_filter-type=AR+D60+window
toco Yes, right item for 2600MM.
