Hi guys,
Shooting tonight and found that when using the Focus module, you can only select a star from the very centre of the frame. Id like to be able to select a star from anywhere within the frame for focus.
For now, the clumsy workaround is having to slew to a bright star and place it in very centre of the frame, focus, then slew back to the framing desired. Don't that, takes time, affects guiding, and is simply unnecessary overall. Would be so much better to be able to select any star to use for the focus module.
    Improve101 There is a green square that you can drag around to match a star. ASIAir will then cut out images around that square.
    The only issue is that I don't know how to reset that.
      wvreeven You get that only after it selects a zoomed in area of the central region.. so there's a total of 3 levels of zoom. There's full image (zoom1), then the default zoomed in central region (zoom2), where you then get that green square to select an area to go to deepest level of zoom (zoom3).
      So I'm asking for the ability to select any area on zoom 1 level (instead of from zoom 2 level).
      Write a Reply...
