I took out the microSD card from my ZWO ASIAir Pro, and put it into a reader so I can back up the card. I noticed that the microSD card got quite hot while in the reader for whatever reason, so I immediately took out the microSD card from the reader. I inserted the microSD card back into the ASIAir Pro. I turned on the unit. But now the ASIAir does not work.  The green CARD light blinks four times, stops, then blinks again indicating a problem with the card. The red WiFi light does not turn on.
Did the heat erase the card?
Do I need to restore the microSD card? Any other way to fix?
