OK Al, check your log to see what occurred.
It sound like your mount is still disconnecting, but we need to know if it is just disconnecting sporadically, or while it is attempting to move. Or did it happen when the ASIAIR was communicating with a different USB device (like an EAF, or filter wheel). That could tell us a lot.
If it occurred while doing a meridian flip, then connectors are almost surely the problem -- but it could be extra draw from the power supply too (the RST-135 sips power, but some mounts could draw an an extra 1 or more amps while slewing). You can test this even indoors by making ASIAIR execute successive GOTO between a location just west of the Meridian to a location just east of the meridian, to see it it stays alive. And also measure the 12V supply right at the mount's power connector to see if it drops while the mount is slewing. Best to do it in the cold, too, but you can do that while it is cloudy.
Make darn sure not to use the USB hub on your camera to connect to the mount. Anything USB from ZWO is poorly designed, and I have an ASI183 hub that would sporadically fail even at room temperature, indoors, and stationary, when I tested it.
There are also multiple ways that your mount could be the culprit.
It is also possible that your mount is sending some response to ASIAIR that it does not recognize, causing that thread in ASIAIR to crash. ASIAIR uses multiple threads (main camera, guide camera, mount, etc) and it is possible for one thread to crash while the rest is still running. But usually, when that happens (which you read a lot about too), you cannot connect back to the mount without a reboot. Well written code will look for bad responses and ignore and try to recover, instead of crash, but not well designed code may just crash.
It is also entirely possible that your mount is back powering the USB -- you can check this with the cheap USB power meters -- see if the Mount's USB hub is putting out any power. If so, your solution may be as simple as adding a USB hub before the mount.
Did you take care and add a ground bus between the mount and ASIAIR? I seldom see astronomy hobbyists do it, but I think that I have mentioned a ground wire that runs between the ground of the ASIAIR and to the ground of my RST-135. This way, I can be sure that the thin USB wires are not the ones that carry the ground return of the 12V supply to the mount. I didn't go as fas as to use a braided bus wire, and simply use 18AWG wire.
It is just weird that so many people are having problems with the ASIAIR.
I still have no opportunity to take the released v1.8 ASIAIR for a spin. Heck, we had our first snow last night. About 1.5 inch of accumulation at our elevation.
