Report the IP address in the wifi configuration menu, or the "About" This will be useful in retrieving image from the device over the network.
    dkrider retrieving image from the device over the network
    Hello,
    You can use station mode:
    When I try this, I get this error in my browser:
    192.168.12.115 refused to connect.
    I can ping this address, and my Deco can see this address is the ASIAir. What am I missing?
    • w7ay replied to this.
      ckoos I get this error in my browser:
      That IP address address does not have an HTTP sever.
      The only usable server on the ASIAIR is the Samba server to access (read-only) the storage on the ASIAIR.
      If you use macos, use the Go Menu in the Finder's menu bar, and select "Connect to Server..." by using the Samba address, e.g., smb://192.168.12.115, you should be able to reach the ASIAIR sever and mount a drive using Guest (no password). From there, the ASIAIR storage looks just like any other read-only volume to Finder.
      I'm using Windows 11. Any idea how to connect using Windows?
        a month later
        ckoos Yes. Download Bluestacks, an Android emulator and then install ASIAIR App.
        Write a Reply...
