SteveZ For what it's worth, I use the “Takahashi Temma 2” option on the Mount Settings page and the total guide error is typically between 1" and 2".
Hi Steve,
I had been able to get 0.7" with the EM-11, with the very poor autoguiding in the old ASIAIR. With the current state of guiding in ASIAIR, I would be surprised if you can't do at least 0.5". With a little patience, perhaps.
I have the pretty old EM-11 that took both 12V and 24V supply, and even with a 24V supply, I still needed to balance the mount really well. Make sure you do that. (I got lazy in my old age, and bought myself a RainbowAstro mount with strain wave gears that don't need balancing, or even a counterweight).
If you are new to all this, be sure to check the web on the topic "third axis balance." If you look down your OTA from the eyepiece end, the left and right sides of the telescope needs to be perfectly balanced -- otherwise the mount balance will change as your telescope tracks a target through the night. A finder of guide scope that is not mounted in the vertical plane could cause this imbalance. And electronic focuser that stick out on one side of the OTA can cause this "third axis" imbalance. A Electronic filter wheel that is not perfectly symmetrically mounted can cause the imbalance, etc, etc.
Here is a YouTube video on what 3rd axis balance is all about:
https://www.youtube.com/watch?v=zmla32ksH_I
I simultaneously connected the RJ cable from the guide camera to the Temma controller AND a serial cable from the Temma controller to the ASIAir using a serial-to-USB adapter.
Yeah, lose that RJ-11 cable (strictly speaking an RJ-12, but most people call it RJ-11). I don't think any signal flows down the ST-4 port when you choose the Temma 2 mount. But at best, it is still extra cable to imbalance your system. At worst, ZWO actually sends pulses down that cable and it will really screw things up. The only time you really need ST-4 nowadays is if you use something like the Hinode solar guider in the daytime. Most software today will handle "pulse guiding" (i.e., guiding using the mount's command protocol), so you won't need ST-4.
I checked the PA with the reticle in the mount and with the PA function on the ASIAir (which said the alignment error was 0.00”)
First of all, you cannot trust the ASIAIR polar alignment to more than 15". Worse if you are aliging with declination angles away from 90º declination. And also worse if you are located at lower latitudes, where the polar region is closer to the horizon (atmospheric refraction).
Next, polar alignment only points the polar axis of the mount to the North (or South) celestial pole. It does not assure that the angle with respect to horizon is correct.
As an experiment, go out one night and look at Polaris (moderately close to the celestial pole for the current epoch). Pan your head sideways (azimuth) and up and down (altitude) until Polaris is "centered" in your view. You have now polar aligned your head :-). Now... tilt you head, while keeping Polaris centered in your view. Notice that you are still "polar aligned" (i.e., Polaris is in the center of your view). But, the top of your head is no longer pointed at Meridian! This is like a mount that is not leveled in the east-west direction.
I.e., polar alignment is not the same as having the zero hour angle of your mount pointed at the Meridian. They are different parameters.
The ST-4 cable connects the autoguide camera to the controller on the mount.
Understood. The ASIAIR sends commands to a camera that has an ST-4 interface.
