wvreeven Not what I wanted to see. It is the discontinued 120mono. It worked with Windows 10 and I note that many drivers used in Win 11 are Win 10 drivers. USB devices older than this camera continue to work.
I did a search and found some posts by people with the problem but I did not see a solution. The old ZWO pack for the 120 will not run in Windows 11 even if you ignore all the warnings. The firmware installer does not see any cameras. If you have link I would appreciate it very much.
