elineberry75 I can ping the IP from my tablet (same one the app is installed on) with no problem so I know it is connected.
Did you give permission in Android to allow the ASIAIR app to access the local network?
It is an easy thing to do with iOS (in the iOS settings for iOS). There should be something equivalent in Android.
If not, try removing the ASIAIR app completely from your tablet. Then reinstall it from the App Store. When you run the new app for the first time, ASIAIR begins with some windows asking for permissions. This time, give ASIAIR full permission to access you network, and also your files (for images).
