@tech@zwo#52615 Thank you for your answer. No, I am afraid the disconnection issues remain because they happen even without having run the capturing programs. That is, I connect the camera and, even before running the programs, it is very easy to lose the connection (it sounds the W10 connection and disconnection sound) at the minimum movement. This does not happen always, either. But it is very frustrating when it happens when you are trying to focus, doing a goto, or trying to capture. It can spoil a job or make it impossible.
The reduced framerates were already solved. As I said in my previous message, they were only a matter of not having checked the High Speed box in the program (FC, AsiCap...).
