paulchen In the moment you have to manually move your telescope into this position.
Scroll the GOTO coordinates in ASIAIR so that RA is equal to the current Local Sidereal Time, and Declination is equal to your latitude.  Then issue a GOTO from ASIAIR.
Choose an RA that is slightly smaller than the LST, or slightly larger than LST, to choose which side of the pier you want the OTA to be positioned to do your flats.
4 minutes of RA corresponds to 1 degree of tilt; so you can ignore the seconds field of the RA.
Be sure to turn off Tracking after the GOTO.  Almost every mount will turn tracking on after it receives a GOTO command.
ASIAIR only supports Right Ascension and not Hour Angle for its "Favorites" objects.  Otherwise, you can simply set a favorite object as one with the declination equal to your Latitude, and Hour Angle of 0 hour (the definition of Zenith).  Allowing HA also lets users park the mount on a permanent pier to any position the user wants.
