Hi guys
I have a question and hope someone can help
I have a Celestron CPC1100 HD that I'm struggling to get working with ASIAIR Pro.
Getting Error: "Connect Failed. The device on the USB Serial Port is not detected."
I'm finding the instructions very confusing on how to set it up to control via ASIAIR Pro. I've read through the manuals and Im still not very clear on the the setup.
I have updated the scope and handset firmware to latest versions. I power on the scope, input time/date into the handset and do a Two Star Align.
No what?
Some guides state to connect the Handset to the ASIAIR Pro. Others simply say to connect to mount. Is through the enet from ASIAIR to an Aux port?
(Does not detect the mount when I do this)
Does ZWO have a simple to follow procedure for setting up the AltAz CPC mount?
Steps would help. For example:
Step 1. Connect handset to.....
Step 2. Align scope
Step 3. Connect X cable to mount/ASIAIR
Any help would be really appreciated as I've tried methods described online without any success.
Thank you in advance.
