Hi,
Until a few weeks ago I had been successfully using an ASIAIR Pro with my RST-135 mount. However I recently switched to an ASIAIR Plus and since then the meridian flip has failed every time. The settings are the same so it’s a bit baffling. When I got the ASIAIR Plus I wasn’t able to use it for a few weeks due to the weather and in that time there were a few software updates, so I can’t tell if the issue is the Plus itself or a software update that would have broken the Pro as well.
The issue is that the when a meridian flip is triggered, the mount doesn’t actually move at all. However the Plus thinks it has moved and initiates a plate solve, which ironically seems to work. However at the end of the procedure the Plus reports that the flip has failed and attempts to do it again. This cycle continues until I stop the auto run sequence and flip the mount manually.
The log reports exactly the sequence of events I described above.
Any suggestions would be welcome.
Cheers
