Jan75 Here is a picture that illustrates the issue and the oily leakage on the sensor.
Probably oil separating from the heat sink grease in the thermal pad. See this thread and the link to a Cloudy Nights thread.
https://bbs.astronomy-imaging-camera.com/d/12654-moisture-in-2600mc
How much did you push the cooling power? The more you push cooling, the hotter the hot side of the Peltier junction gets.
I suspect this is a case of cheap thermal pad, or inadequate heat sink size (in the camera), or insufficient fan size/speed. I have not seen it on the other manufacturers' cameras.
With normal quality grease, the oil separates only above 150ºC to 165ºC.
Will your dealer take the camera back? It is obviously defective.
