allen456 The AA+ simply does not let me do that because the button is disabled. Do you know a way around that?
Is the ASIAIR Mount Setup still connected to your mount? It has to be disconnected for that Next button to be activated.
The procedure is this:
1) go to the Mount Settings window and disconnect the mount (the green slider toggle on the right).
2) select "PA" window.
3) tap on the big fat arrow on the right
ASIAIR will warn you that there is "Mount No Connection".
Tap on Skip, since you specifically don't want to connect to a mount!
ASIAIR will do a plate solve.
That is when the Next button should active. But don't tap on it until you have manually moved the RA by 45º to 70º.
If you do not see that button activate, then there is a some particular bug associated with your set up. You will need to wait for ZWO to answer you.
If the Next button shows up (if the plate solve succeeds), proceed with the instructions to correct altitude and azimuth errors, and when you are done, go back to the Mount Settings window to reconnect ASIAIR to your mount.
