Hi Bruce, I have the a similar issue with my EAF, but with EAF firmware version 3.3.5 which seems to be the latest release. Connecting the external temperature sensor at ambient 20 celsius shows a seemingly random temperature. Did the issue ever return with your EAF?
Steps to reproduce issue with my EAF:
-Connect EAF without external temp sensor connected: ASCOM shows T: 20.5C.
-Connect external temp sensor: ASCOM shows T:83.8C.
-Disconnect external temp sensor: ASCOM shows T:20.5C.
-Connect external temp sensor: ASCOM shows T: 56.2C.
Temp sensor is attached to the tube with insulating self-adhesive foam.
I tried re-flashing the 3.3.5 firmware, but the issue persists.
Thanks.
