WillemW Can I use a 10 dbi wifi antenna for my Asiair Plus to increase wifi range?
Keep in mind that to establish a WiFi connection, the ASIAIR needs to not just transmit well, but also have a decent signal-to-noise ratio (SNR) in the receive direction. Increasing the gain of the antenna will not help SNR if the interference is coming from same direction as the increased directivity of the antenna.
From all the complaints that I have read, I highly suspect that peoples' problems are caused by the receive direction (not enough SNR), and not by the transmit direction (not enough power). I.e., living in suburbs that are saturated with WiFi devices. The only help in this case is to increase the transmit power of the WiFi router. It could simply be that your neighbor already has his/her router set to much higher power than your router (yes, you can change the power levels from many WiFi routers). If your drop outs are intermittent, they could come from other sources in your own house (since it is in the same general direction as your router) that use the same "license free" 2.4 GHz ISM band -- cordless telephones, microwave ovens, weather stations, soil moisture sensors, and even nearby Bluetooth devices. Of course, it could also come from any of your neighbor's devices as well.
Drive the ASIAIR away from your neighborhood to a clear field in the countryside, to see if it works better. If it does, then the receive direction is your problem, and a higher gain antenna may not be the cure, if the interference is arriving at the ASIAIR from the same direction as the increased gain of your antenna.
If receive SNR is the problem, a higher gain (i.e., higher directivity) antenna only helps if the interference is coming from a different direction as the direction of the antenna's main lobe.
Secondly, antenna gain is achieved only by increasing its directivity (i.e., conservation of energy). If the signal is stronger in one direction, it has to be weaker in a different direction. By definition, an isotropic dipole radiates equally in all direction, so, the solid angle of the directivity pattern is reduced by 10 decibels (the "i" in dBi refers to an isotropic reference antenna), or a factor of 10 smaller. The gain of a "10 dBi" antenna is thus about 0.4 * pi steradians.
With a higher gain antenna, it becomes even more important that the antenna does not move through the night. If your current dropouts are caused by your mounting the antenna on the OTA, the problem could become worse, not better. Mount your antenna to a stationary point, like the tripod leg.
That being said, since it is not isotropic, a typical short dipole (probably what came with the ASIAIR, although ZWO neglected to publish the radiation pattern of the ASIAIR) has a gain of about 2.2 dBi. So the gain that you achieve with a 10 dBi antenna is probably only 7.8 dB better than what exists today.
Thirdly, keep in mind that antennas (again, by conservation of energy) works as an inverse square law. If all else (interference, average path loss, etc) is equal, an extra 6 dB of antenna gain will only improve the distance by a factor of two (not a factor of four), and as mentioned in the first paragraph, if your problem is caused by interference in the direction of you router or tablet, then distance will not improve one iota anyway.
