Has anyone connected an EAF to a Vixen Visac 8" telescope?
Hazelnut You can refer to this guide to check if EAF can connect to your telescope.
I have a Vixen VC200L VISAC catadioptric and I couldn't fine a way to make the EAF work. Let us know if you do !
@tech@zwo#54440 It's not an answer. Is it possible connect EAF to VISAC? If yes, how can I connect them?
Unless somebody already did it, there isn’t an answer if the bottom of the focused has some threaded holes there are chances to connect the ZWO plate and the all the rest of the EAF you should search in Cloudy nights forum
