You can use the mobile portal, i.e., https://mobile.facebook.com/groups/ASIAIR/ instead of the www portal. You can see all the replies. The only thing you can't do is to expand the selfies images, which, believe me, is no big loss.
If you are using Safari, a better way (and prevents Zuckerberg from tracking you) is to open a New Private Window from Safari's File Menu. You can then go to the www portal, and can click on pretty much everything, including the selfies.
