I was looking through the ZWO Facebook page when it required a login. I do not have a Facebook account, nor do I want one. Is there any way around this.?
JohnD
Yes; use this site and make sure you never use Fessesbook
Like I do.
    Unfortunately ZWO seems to post updates there instead of here, especially info on upcoming releases. I found a way around the problem. I just needed to delete the cookies that Facebook inserted in my browser. Then I was able to see everything again.
    JohnD
    galactique Is there any way around this.?
    You can use the mobile portal, i.e., https://mobile.facebook.com/groups/ASIAIR/ instead of the www portal. You can see all the replies. The only thing you can't do is to expand the selfies images, which, believe me, is no big loss.
    If you are using Safari, a better way (and prevents Zuckerberg from tracking you) is to open a New Private Window from Safari's File Menu. You can then go to the www portal, and can click on pretty much everything, including the selfies.
      You are right, but ZWO is blasé about it.
      Regarding FB cookies, I too got rid of them and I do not intend that they replace them :-)
      w7ay
      Hi Chen
      At first I was very irritated to be 'excluded' from by FB policy.
      But now I do not care, I do not miss them.
      Write a Reply...
