Hello. I have been using my ASIAir Pro together with the ASI294MC camera for a while now without a single problem. Had the setup out for an imaging autorun 2 days ago as well as yesterday on the same target. Am using the supplied thumb drive to save the files, has worked flawlessly so far. Wanted to now to transfer the light and calibration frames onto the Mac, but yesterday's lights are missing. I have the ones from 2 days ago, as well as yesterday's dark and bias frames. The log file shows the full autorun went through. When I plug the thumb drive back into the ASIAir Pro, i see the files, all in .fit format as they should be. Here are the screen shots of the ASIAir Pro Image Management file, clearly showing that the files are there. But not on the Mac. Any thoughts or suggestions on what could cause this, please? Here are the directory screen shots. Calibration frames as well as a Preview frame and a Live stacked frame from yesterday are showing.
fourthfloorastronomy Could you check this?
@tech@zwo: Thank you! I had to go the Wired LAN route to retrieve the photos, all is good now! Still don't know what happened but at least I am now familiar with more options to retrieve my shots, should this happen again 😉 Again, thank you!
