I am changing my +5 year old ZWO ASI1600mm Cool camera for an ASI294MM Pro camera and understand thet they are effectively interchangable regarding focus, apart for some tweaking.
Does this mean that the 294 can / will use the same driver as the 1600, if not which driver should I use for the 294?
Also I see the 294 cooler power is rated 12v 3a, would there be any problem / benefit using a 12v 5a charger or should I just stick to 3a?
Thanks, Graham
