astrovienna The mechanical drawing of the 7 x 2" version of the EFW shows that the filter openings are M48x0.75 threaded. What is the clear aperture of those openings?
An M48 opening has a thread with about 48mm in diameter.
However, you then need to subtract the thickness of the spacer from the radius, which depends on the thickness of the wall of the spacer that you use, but typically 2.5mm to 3mm.
That means the hole will typically be between 42mm and 43mm in diameter.
The location that you place the filter depends on the exit pupil of the final lens (or reducer) of your OTA, and that will affect the size of the hole. With an exit pupil that is smaller than the diagonal of the sensor for example, you want the filter to be closer to the exit pupil than to the sensor.
I usually just draw out a diagram for geometric optics, and give it an extra half a millimeter to account for diffraction optics.
So yes, to avoid aperture vignetting with a full frame camera (42mm diagonal), an M48 hole is pretty much "unmöglich," unless the exit pupil of your OTA is much smaller than 42mm, and you place the filter wheel near the exit pupil of the OTA). "Conventional wisdom" is to place the filter as close as possible to the sensor, but that only works if you don't have a reducer (or a Petzval arrangement). This is where following old wives' tales blindly without thinking will lead to problems.
You want the optical path to fully clear the tubes. Otherwise you will not only get just an intensity fall-off (correctable with flat frames and/or cropping), but other ill effects of aperture vignetting from diffraction effects (that are not correctable with flat frames and/or cropping). Here is one of them:
https://www.cloudynights.com/topic/547028-anyone-know-what-causes-this-artifact-on-bright-stars/
You might be able to find really thin-walled spacers, but then, you could have flexure. Just shop for a different filter wheel. The ZWO wheels with M48 openings are just not suitable for full frame cameras. Find one with at least an M54 opening.
On top of that, the metal rings from mounted 2" filters (M48 thread) can be limiting the aperture too. This is why IDAS makes a set of 52mm filters in addition to 48mm (so called "2inch" filters).
